Joopin
Super Moderator
NP231 on my 91 YJ...
I was wheelin yesterday and I had to pull a guy out again. In doing so I broke my front shafts U joint on the T case end. When the shaft was floppin around in there it knocked off the linkage that goes from the T-case shifter to the T-case.
It looks like the two ends just pop back in the holes, maybe held with a pin of some kind on the other side. You definately have to force it into the hole.
I was wondering if I can just use the one that popped out again or do these linkage ends go bad so they pop out easier. Any ideas would be much appreciated.
Joop
Joop
