MY RUBI HAD A BAD DAY!
whiterubicon
Yesterday was a bad day for me and my Rubi. It was coming up on 9,000 miles and was time to schedule it for an oil change. I called the dealer and made an appointment for that day. About 2 hours later a coworker came to me and said that I should check my jeep for damage. "Why?", I asked. She told me that a branch fell from a tree and it looked like the jeep got hit. She was correct. The branch was a bit larger than a shampoo bottle and about 15 feet long. It hit the drivers front fender and bent it down. I was sick. Since I work in a bodyshop I pulled the Rubi into my stall and began drying her off to see what else might have happened. The damage looked bad but only required a bit of tweaking to the fender and it was good as new. The fender flair will need to be painted but that is not so bad.
Since I have heard about a problem with the Rubicons leaking fluid from the rear output seal on the transfer case I try to keep an eye on it. Well I decided to look under there since I had it on dry ground. Guess what. It is leaking. The guy at the dealer said that he hadn't heard of this being a prob. They fixed it according to a TSB from Jeep. I just hope that it is realy fixed and I dont have to play games. I was suprised to get my Rubi back today. Today was a much better day.
i'd be mad if a big ole branch fell on my jeep. infact, i'd be pissed as hell. Atleast you was able to fix it easy
My buddy bought a Rubi two months ago and his seal was leaking 3 days after he bought it. Had it replaced under warranty and it was leaking again a week later. He had it replaced again and no further problems. He's a little pissed at me right now because he got his fully locked Rubi stuck on a rock which I drove right over with my unlocked YJ just before he got stuck and had to pull him out.
He may not of heard of it, but apparently Jeep has if they've issued a TSB on it. Don't be surprised if it leaks again, it's the nature of seals sometimes, it often takes a few tries to get a seal with the perfect fit. Can't take 'em more than about 15 minutes to fix.
