If they both are made to bolt to the hinges, they should both have the same hole patterns. Can you just bolt one over the other and use longer bolts?
Couldn't you just weld some small tabs to the bottom of the light bar?
I could just weld to the bottom but I was planning on getting a stainless bar. The problem with just putting them on over each other looks like they would interfere with each other. I seem like in every picture I see the part of the windshield bracket that the light hooks to would hit the bar or at least the light would hit the bar.
