Rims and tires
hebstang
I own a 1981 JC7 with a AMC 20 rear and a 30 dana in front, i was wondering if i can use wrangler rims on my truck. I have to get it to pass inspections and i just want to put some small tires on the truck for inspection. Thanks, hebstang
Im not sure, but I think that the CJ's had a 5x5.5 pattern and wranglers a 5x4.5 pattern. So no, wrangler rims wont fit on a CJ.
Nathan
The rims off of a pre-97(?) 1/2ton fullsize Ford will bolt on. Same goes for 1/2ton Dodge rims too, as long as they have the larger hub hole in them.
You should post your location. Some one may be able to loan you a set they have laying around.
