GaryMB
I recently purchases a 1984 cj7 with a 258 (has the carter bbd carb w/electric stepper motor). The jeep had an HEI distributor already on it when i bought it, and i do not know if this modification is california smog legal. I know there is a sticker in the engine compartment that has a diagram of the original distributor and coil, and says the sticker must not be removed in order to pass the visual inspection. I have the original distributor and ignition stuff, but don't know if the distributor works and it has some rust on it which makes me hesitant to stick it in the engine even after cleaning the rust off. Also, is the nutter stepper motor bypass CA emissions legal, and is the bypass desireable? Right now the jeep has issues with dying when i start it, and sometimes when i coast to a stop. It also seems to have a rough idle, and you can constantly hear the exhaust pipe going putt-putt. I've heard the nutter bypass can actually lower emmissions in jeeps with these problems, but it might ironically not pass the visual inspection if it is not a legal mod. Also all the smog stuff minus cat converter and computer have been removed (i know at least the pulse air system and vacum setup are gone). Any suggestions or comments on the HEI, nutter bypass, and what i'm in for with making the jeep pass smog?
