Thread: 92 yj axle help
  1. 1043762
    My 92 yj was in an accident, the passenger side hit a tree the leef spring is bent and the axle hit the shock and put a small dent in it, also the grill is pushed back off the plastic by 3/4" the tire is back maybe 2" is the whole axle and steering shot.. Please help [addsig]
    1043763
    A dent in what? The axle housing or the shock?
    Are you having a mechanic look at it? The housing needs to be checked for straightness and all the internal parts should also be checked. Housings are pretty tough, it's the rest of it that can be weak.[addsig]
