Thread: axle seals
    RE: still need help on axles
    i am following a haynes repair manual and was under the assumption the hub had to come off to get to the seal. I went and picked up the seals and understood while I have the axle out it would be pretty easy to replace both seals while I'm in there. I wish I could afford to do the one piece axle but jeep money got spent on cows. I'll limp along like this I guess. Thanks for the reply.
    I think you hit 'new topic' instead of 'post reply', looks like you meant this to be in your other thread.
    I'm not that familiar with the AMC20, I don't know how hard it is to remove the flange from the shaft.
