You can put 35's on there with a 2" lift, but the back spacing on your wheels will dictate rubbing during turning. also, one of two things, you willneed to do a SOA on your 2" springs or,
Some body work install those, remove the front fenders and radius a clearence into the hood. You can buy a hood already like that, But I forget the manufacturer. also, you will have to Bob the rear quarters (cut them off) and go to a fuel cell, as well as stretch the rear axle back by 3 inches by welding new off set perches onto the axle. It can be done, and we did it. but lots of engineering went into what we did.
