Carter BBD Idle mixture setting?
Jasper Jeep
Can anyone give me an approxomite number of turns out for the odle mixture screws to use as an initial setting for my newly rebuilt carb?
It's on a '79 CJ7
thanks!
Try turning the idle mixture screws in until the Jeep almost dies then take them out one full turn, that is a pretty good start point. Make sure the engine is nice and warm.
id turn each of the nuts at the four corners of the base on the carb-intake mount enough to where the carb can be lifted off. then Id cut every hose and wire going to it, and using 100lbs of force, -rip it out of the engine bay, then whip it in the garbage can. install a new weber or motocraft and you should be experiencing excellent idles, graceful acceleration, never a stall, and glorious performance.
