Clutch HELP!!!
Sobol
i have a quick question, yesterday i was driving and the clutch went right to the floor and wouldn't "reprime" i bleed it out today and it held presure then went out again. i think i heard a hiss of air by the master but could find no fluid anywhere. so a little help plz... could it be the gasket in the master i dont know. and is gravity bleeding ok i mean will it get the air out.
Did you check under the dash where the master comes through the firewall? It will usually leak on the inside of the jeep. Could also be your slave. Don't know for sure on your year but my 93 has an internal slave which involves removing the transmission....pain in the butt!
ok well i checked in the jeep and there is a leak... Picking up a new master cylinder today. i'll let you all know how it turns out.
