knock in trans.
ezj001
87 yj,put trans in nutral and no foot on clutch,apply some pressure on shifter and it sounds like the engine has a knock.pulled trans.output shaft barring is bad,but by hand when turned it has a clunk like a bad tooth,ect.it has a 4.2 with either a ba 10 or 15 not shore which.need to know which side to lay the trans. to open it.any help would be appreatiated.even where i can get a repair manual on the ba 10 /15 trans.
thanhs,in advance
ezj.:???:
It's the Peugeot BA10/5 transmission, sounds like a bad gear but I wouldn't know how to take one apart without a manual.
