    Ohh Noo The Brakes!!!
    so today were gettin about 8 inches of snow. I have a 99 wrangler. And me and my buddies tide a sled to the back and pulled. at one point one of the kids that tagged along not really a friend decided to pull the e brake. Now my light wont go off, and the regular brakes are really loose? like i have to push down all the way to get any kind of stopage! SOME ONE HELP BEFORE I DIE!!
    IF ITS NOT A JEEP GO AWAY!!
    http://www.myspace.com/puglise
    Jan 2004
    Blacksburg/Williamsburg VA
    2,573
    Re: Ohh Noo The Brakes!!!
    You just need to adjust the e brake, he probably wore the crap out of your rear pads. The same pads are used for the ebrake as for the the hydraulic brakes in the rear cuz they're drums
    06 VW (hardcore crawler)
    "The mountains are calling and I must go." -John Muir
    You need to adjust the rear pads, remove the rubber plug from the backing plate and adjust the starwheel to move the pads closer to the drum. Move until they drag slightly and back off a little.
    And check the fluid level in the master cylinder.
    its safe to drive tho right?
    Nov 2005
    Murfreesboro, TN
    660
    Quote Originally Posted by laxpug19 View Post
    Judging by that i'd say you need to fix it before you do any good amount of driving
    The poster formerly known as Red93...
    '93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
    http://www.myjeepspace.com/wrangl3r93
    http://www.tnvjc.org
    Aug 2006
    Muscle Shoals,AL
    426
    Also check to see if the E-brake cable is working or is it froze up.
  7. #7
    Dec 2006
    San José, Costa Rica
    1,693
    I think new friends may help the problem from returning, though... LOL
    '94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, Adv. Ad. SYE, Woody Shafts, Alloy Axles, ARB Lockers, 4.88 gears, 62mm TB & Spacer, 165A Alternator, Griffin 3" Aluminum Rad, Taurus e-fan w/ DC Controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Adj. FPR (42PSI), MOPAR cam, Safari Snorkel, 33" BFG KM2, 15" AR wheels, Xenon H4 lights, KC Daylighters & Slimlites, Sony sound, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers, Rhino lined Tub.
  8. #8
    lol, i knew it was a bad idea. DAMN PEER PRESSURE!
