anyone got any tricks to getting a replacement top to fit right. i got one of the pavement ends tops with the door skins. when i put it on the doors keep sticking to the top , its really annoying .
- You can adjust the angle of the windshield frame which alter the tension on the top.
- You can adjust the the doors at the hinges.
- The bracket that the softop frame plugs into directly behind the door is adjustable by about an inch if you loosen off the bolt and slide it forward or backward. It will adjust how tight the frame is around the door when it is closed.
