01 TJ - brake lights turn signals not working
native
Hey, I have an 01 TJ and the brake lights, flashers, and turn signals are out. I have replaced the turn signal switch, flasher fuse and a corroded parking light socket. I am not sure where to go from here. I am not sure if the brake light switch could be out or if I should start following the wires running from the brake lights. Any advice would be great.
Is it all the lights? or just one? front and rear?
Both the front and rear turn signal lights are out as well as the all the brake lights including the middle. The parking lights work all the way around even on the back.
