jfrabat
OK, so as many of you know, this is my first Jeep. A couple of months ago, I decided to change the hood latches on the YJ, as the stock ones were starting to rust (you can even see the rust stains from where the water flowed through them).
I bought the Rugged Ridge complete hood set from quadratec, and installed it, but i started noticing that the hood kept wanting to come open at highway speeds. I checked the latches, and one was much softer than the others. Because of the obvious dangers of having the hood pop open, I decided I would spend the extra money and get the stock latches, so on Tuesday I went to the stealership and bought them ($80 the pair!). Anyway, they did not have them in stock, so I picked them up yesterday. But yesterday I was busy, so I did not get a chance to install them.
Today, as I am driving to work, the highway was jammed, so I decided to take the back routes. While doing about 40 mph, I hit a small bump and next thing I know, WHAM! The hood pops open! Luckily, only the hood got damaged, and I was able to pull over right away.
But I can just imagine what would have happened if the hood had decided to pop open when I headed to Naples last weekend, without the hard top, and at 70 mph with a headwind.... Even if I had taken the highway today, it would have been pretty bad, I think! Has anyone had something like this happen? I think the stock latches are much more stronger than the Rugged Ridge ones, and it seems that this caused the accident, but I am not sure... Any comments on this?
Felipe
Felipe
