Thread: Dome light
    Dome light
    I know I should search, but I'm tired after working on this new Jeep. It's a 1998 TJ. I know I've seen it, but how do I keep the dome light off when riding w/o doors? I have other questions too, but I'll hold off for now.
    Re: Dome light
    I just unplug the wire at the door on my YJ.
    Nov 2005
    Murfreesboro, TN
    660
    Re: Dome light
    The poster formerly known as Red93...
    '93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
    http://www.myjeepspace.com/wrangl3r93
    http://www.tnvjc.org
    May 2004
    Nags Head, NC
    3,909
    Re: Dome light
    On my '03 I just pulled the fuse. Can't remember which one it is at the moment, but it should be listed in your owner's manual. Quick, easy, and cheap!!
    Just Enjoy Every Possibility!
    Jun 2003
    Clovis, California, United States
    953
    Re: Dome light
    Pull the fuse! Only problem with that is it's also the dummy buzzer if you leave your headlights on when you get out. Only did that once though. Of course ever since I broke my dome light buttons off I don't have to worry about it either way.
    '01 TJ, 4.0/5spd
    6" Rock Krawler X-Factor Long Arm, 35" BFG M/T's
    4:88's, ARB's
    BOHICA!
    Re: Dome light
    fuse #17 in back of the glove box.
    blatant jokessubliminal sarcasmsexual innuendo
  7. #7
    Dec 1999
    Virginia Beach VA
    8,002
    Re: Dome light
    I personally like this:
    http://www.quadratec.com/products/13029_200.htm
    The fuse is hard too pull - too little for my hands. I have the spring things, and they work reasonably well, but I seem to always leave them on, replace my doors, and try to close them.
    My 2005 Wrangler Build Thread
  8. #8
    Oct 2005
    Fort Lewis Washington
    513
    Re: Dome light
    Pull the fuse. Its the cheapest way. Unless you leave your lights on and ruin your battery.
  9. #9
    Re: Dome light
    Thanks guys! I appreciate the help. I knew there was something you could do.
  10. #10
    Another Question
    Got another question now. Sometimes when I start the Jeep, my dash does not work. When this happens, I can usually flash the lights a few times and the dash will begin working again. Someone told me a clockspring might be the issue, but I don't know what they were talking about. Any ideas?
