95 YJ ABS lines- more length or disconnect?
Crew11
I've installed a RE 2.5" lift- it comes with brake line extensions but does not mention anything about the ABS wires to the front wheels. What options do I have with these things? Thanks.
'95 Sahara
Is there not enough slack in the lines with that small a lift?
I'd pull more wire loose from the frame and gain length from the frame to the axle.
