1. Question Speedometer hook up 2004 in an '89??
    We're not done yet! I still need help!
    I have an article that was done a few years back on another Jeep website relative to doing a 4.0 OBD II swap into a YJ etc...... in it they call out using a VSS (Vehicle Speed Sensor) & adapter from a 91 Wrangler and they even list P/N's and the old speedometer head works with the new trans etc..........
    I don't have a '91 Wrangler donor car laying around so I called over to the NAPA Store & yep they have a listing. The only problem its like $90 & I figure somebody has come up against this situation and has figured out a cheaper way!
    I'll count the poles as I speed past them before I lay out $90 to square away a speedometer cable problem!
    Re: Speedometer hook up 2004 in an '89??
    The electronic speed sensor from a '96+ will bolt right in to your transfer case in place of the mechanical sender. I may have one laying around. Does this help or am I misunderstanding what you need?
    I don't have the article in front of me right now, it's over at the garage. Anyway, I have a 2004 Engine, trans & transfer case that we're putting in a 89 Wrangler.
    The speedometer drive on the new setup is electronic, like you said 96 & up etc. I have this........ The speedometer head in the 89 is driven by a cable thus they are not in sync with each other.
    According to the article, he used a Part # (which I have at the garage) & Part # (the other one which I also have at the garage) out of a 1991 Wrangler, I believe he called them a VSS (Vehicle Speed Sensor & an Adapter.
    I called over to NAPA and they said they have a listing & could get it but it ran about $90 - I figure there's gotta be a cheaper way? Maybe?
    What do other guys do???? Thanks, Jim
    So you're wanting to retain your cable driven speedo AND send an electronic speed sensor signal to the engine computer?
    A '91 may have the parts you need, that's around the time they switched from cable speedos to electronic, but I know of no other way than to get the adapters.
    Another option would be to get an electronic speedo from a '91-'95 YJ and do away with the cable completely.
    Quote Originally Posted by 60 Biscayne View Post
    Wait, there are other Jeep websites? I must investigate this!
    Life is a trip, so give me another hit!
    SDMF
  1. 94 GC, No speedometer and overhead information console
    By england0602 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-02-2007, 10:43 PM
  2. no speedometer
    By bretman38 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-11-2007, 10:49 PM
  3. 2004 rubicon automatic transmission, and some other parts
    By B.Jones in forum Items for Sale, Trade, or Give Away
    Last Post: 04-24-2007, 02:59 PM
  4. Liberty Stalling, Speedometer, & Rough Idle/Shifting Pro
    By balloo93 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-04-2006, 07:06 PM
  5. Ski for Free!
    By jps4jeep in forum General Chat
    Last Post: 11-24-2003, 11:08 PM
