Still not running
My '94 YJ is still not running. I've replaced the cps, tps, all relays, and checked all fuses. Nothing, no voltage to the coil. I don't know if it's the ecm or not. I do not have any turn signals and the wipers don't work either, but the flashers do work. Someone told me that it could be the ignition switch has gone to the bad, could this be true? It will turn over but not fire. I'm stumped. Don't know the correlation between the turn signals, wipers, and no fire.
I would agree with the ignition switch problem with your info given. Everything you mentioned that does not work goes thru the ign switch Test the main wire feeding the ign switch for voltage...if none then probably a bad fusable link in that main ign switch feeder wire. This is assuming that the 94 had the fusable link protection in that wire. LBR
