1. How to remove oil filter housing
    I have a 93 grand with the 4.0l engine. I need to remove the oil filter housing to replace the o-rings. Everyone says to use a T60 bit. I cant see how that fits onto my housing. The recess in the bolt appears much larger than a t60.
    Can someone help me here. Thanks, Mark.
    Re: How to remove oil filter housing
    Can you post a picture of it?
  1. 90 yj air filter
    By yjmudder90 in forum Wrangler and CJ
    Last Post: 11-26-2007, 03:03 PM
  2. Fuel filter/ pressure regulator install order?
    By RLBJeep in forum Wrangler and CJ
    Last Post: 02-07-2007, 10:12 PM
  3. Air filter conversion
    By Junkpile in forum Wrangler and CJ
    Last Post: 10-19-2004, 08:01 PM
  4. thinking of replacing your fuel filter? do it! it's easy!!
    By berettajeep in forum Cherokee, Commander, Wagoneer and Liberty
  5. oil filter leak
    By balloo93 in forum Cherokee, Commander, Wagoneer and Liberty
