Page 1 of 2 12 Last
    Talking Ticking in the engine?
    Just the other day I gave my Jeep an oil and filter change and I started noticing a little ticking in the engine department. Not sure what this is if it may be cold or what it tend to lessen as it warms up. I also noticed that the transmission fluid may be leaking a little from the drain cap below so I tightened it? Would this cause that?
    Re: Ticking in the engine?
    What year and model jeep?
    Try replacing a qt. of oil with a qt. of transmission fluid and see if the tick gets quieter.
    Look closely for an exhaust leak, could be the cause.
    How many miles are on the engine? It may just be coincedental with the oil change, but If it's higher miles, it's more than likely just cylinder wall wear and makes a rattliling/ticking noise until the motor warms up and the pistons expand to make the rattling quiten down.
    Hey Bounty, what would the Transmission fluid do for the oil?
    l _____
    /l ,[____],
    l---L –()lllllll()-
    ()_)-()_)--o-)_)
    <img src=https://www.jeepz.com/forum/cacheJeepzImage.php?img=http%3A%2F%2Fi189.photobucket.com%2Falbums%2Fz154%2Fjonlipford%2FToys%2F011.jpg border=0 alt= />
    Dec 1999
    Virginia Beach VA
    8,151
    Did you go from a heavier weight oil to a lighter one?
    I use to have some older cars that would smoke and rattle - swapping in some 20W 50 would quiet it right down
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    I've always used 4 qts 10W 30, but I did use a different oil filter this time used Fram instead of the normal K and N. So, just poor ATF down the where you put the oil? Will this end up being a bad idea later on? 03 Sahara 6 cyl 57K
    Dec 1999
    Virginia Beach VA
    8,151
    Maybe the fram isn't flowing as much oil?
  7. #7
    Good chance the exhaust manifold is cracked, more common with that mileage than an internal tick. Inspect the exhaust manifold closely, especially at the welds where the tubes meet.
  8. #8
    4 qts in a 6 cyl is not enough oil... Check your manual.
  9. #9
    Quote Originally Posted by jay79cj7 View Post
    yea, I pour 5 in mine
    l _____
    /l ,[____],
    l---L –()lllllll()-
    ()_)-()_)--o-)_)
  10. #10
    Thanks guys.
  11. #11
    I added another quart of oil and it is still ticking. Check my transmission fluid levels and they are good. Still ticking in the engine I really don't like the noise. I'll take a close look at the exhaust manifold tomorrow.
  12. #12
    I'm almost positive that the only time it ticks is when it cold and not warmed up yet.
    What does this mean?
  13. #13
    It means you may have a lifter sticking, very common, add a qt. of ATF to the engine oil. Works wonders.
  14. #14
    Alright I'll do it.
  15. #15
    I added the ATF to the engine oil and started it and the ticking has ceased. I'm hoping that it doesnt come back. Thanks for the help B.H. now is something that I'll have to do every time I change the oil now or just when I hear the same ticking noises?
  16. #16
    I have the same question about this that the OP asked, so I'll bump. Is this transmission fluid trick a temporary thing to clean out the engine that you can do before an oil change, or is this something you guys leave in the engine for a while / permanently?
  17. #17
    Leave it. You can try running every other oil change without it, but it may come back. Experiment with it and see.
    My mechanic told me about it, he had a sticky lifter in a 4.0L that he would remove and rotate, only to have the tick come back. ATF did the trick.
  18. #18
    I'm still getting the ticking even after I put the ATF with the engine oil. Is it still the lifter sticking?
  19. #19
    if you still have ticking after the atf trick you may have a collapsed lifter or bent pushrod or valve.... you can try pulling the valve cover do a visual check on the upper valvetrain and check the pushrods on each valve (rotate and check your clearances for ea. valve...) - if its persistent it may be beyond the easy fix - just make sure the noise is internal and not an exhaust leak....
    Bob in Florida
    89 YJ-4.2/5spd,Herculiner tub,4"HellCreek Lift,Cable front axle,Flush LED tailights,Hella,KC,33x12.5 BFG M/T on Eagle Alloys,flatfender,55w backup lights, Steves Jeep Rear bumper,Bestop extendatrunk w/top mounted spare,Cobra CB w/rear dual antenna, misc. trail rash
  20. #20
    I would rule out an exhaust leak before tearing into the engine.
Page 1 of 2 12 Last
  1. a ticking into a knocking
    By floyd5194 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-21-2007, 06:38 PM
  2. YJ ticking
    By Tink in forum Wrangler and CJ
    Last Post: 09-09-2005, 10:35 PM
  3. Log In is ticking me off
    By redrooster in forum General Chat
    Last Post: 06-24-2004, 06:34 PM
  4. ticking
    By Saurian in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-28-2004, 12:45 AM
  5. Ticking Noise
