lighting question..
darkwolf
ok,it's freezing in hollandia and i don't have a warm garage...
i'm gonna work on my jeep anyway cause i finally have some time for it.
i want to build in my chokelever and fix the lights tommorow....brrrr.
here's my problem,what is the normal lighting of a cj in u.s.a.?
the rear is allready covered so what i need to know is how to switch the frontlights in a original way,
1-do the front side-orange turnsignals stay on when not flashing?
2-what is the original purpose of the small headlights?turnsignal?
3-what or where are the citylights
maybe someone can post an electric scedule?
any help welcome,
darkwolf
[addsig]
1049950
are you being serious?
when you pull the headlight switch(click once),all lights come on except the headlights.
pull the switch one more time and the headlights should come on.push on the floor mounted switch to control the bright lights.
lights on,left turn signal on,the rear and front will flash together and the front side will flash when they dont= .....click click click click click click
..................................front+rear. on .. off .. on .. off .. on .. off
...................................front side . off . on .. off .. on .. off .. on
same if you put on the right side.
lights off,the three will flash together
hope this makes some kind of sense
[addsig]
