Thread: Carb for 258
06-29-2009, 11:23 PM #1
Carb for 258
I an a newbie to this site, it came very highly recommended from friends on a Dodge Cummings Forum site!!!! I am going to change out the tired carter BBD. I am told that the best bet would be a Weber K551, I am also hearing a lot of good feed back on the MC 2100... They are both close in price so that is not my issue, It is a daily driver and trails in the forest on the weekend. Any info will be grateful. Thanks, Paul
06-30-2009, 04:08 AM #2
Re: Carb for 258
Can't go wrong with the MC 2100, i ran one before I switched to EFI and it never gave me any problems. Then again, there are plenty of people who have had success with the weber as well.
BAMFCJ7
06-30-2009, 12:04 PM #3
Re: Carb for 258
I have to say that the weber has been great! That thing runs hard! So far I havent had any compaints!
USMC Low Crawler
06-30-2009, 01:13 PM #4
Re: Carb for 258
Weber is OK only if you get a good one out of the box and they don't all come that way. Under the "been there done that" category the one I bought was bad and Redline (the maker of the Weber carb) left me hanging in the breeze. If you are buying a new one it says on the outside of the box "No warranty whatsoever" and from my experience they mean it. Why take the risk when the Motorcraft 2100 - 2150 is so reliable.
06-30-2009, 02:56 PM Thread Starter #5
Re: Carb for 258
Well I think the MC 2100/2150 is going to be my choice, I can get them at about the same $$$... The MC is a very simple carb to work on down the road. Thanks, Paul
06-30-2009, 09:58 PM #6
Re: Carb for 258
The MC2100's deal, is that you get one for $25.00 to $30.00 at the nearest junkyard. You then rebuild it, (easy as pie) with a kit from the local big box parts house. (Advance Auto, Autozone)
The adapter is Mr. Gasket #1937, & you fab up some linkage using a cut off piece of the throttle lever from the BBD with it's ball stud. That gets bolted to the MC2100's lever;
Best to do the "Nutter bypass" with this too.
This is a Picture Guide to Nutter Bypass - JeepForum.com
Also the "TeamRush Ignition upgrade" works well with these.
Genuine Junk Yard Genius.com Ignition Upgrade, Jeep 258 CID I-6Forums/CORF Carolina's & surrounding states.
Forums/CCOR Eastern Carolina's.
I have more redneck mods than you!
1990 YJ 4.2L AX-15 on board 220 amp alternator welder, York OBA with rear bumper air tank, Hitch mount front or rear XRC8, Junkyard tube doors, MC2100, TeamRush ign., 60" Hi-lift w/Jackmate, Homebrew cage add-ons, Homemade 1/4 ton trail rack, removable hood-windshield-tailgate, soda bottle coolant & W/W reservoirs Home built stinger & dual hitch front bumper..............
07-02-2009, 07:50 PM #7
Re: Carb for 258
Go with the Weber I liked my on my CJ7
Rubicon Rich PatriotJeepers, Inc
05 Rubicon
86 CJ7 ,258,T18,Scout Dana 300,Dana 44's,Lockers,Twin stick,OBA,8274 Warn winch.
51 M100
Best Carb to buy for the 258
By TXFour in forum Wrangler and CJReplies: 26Last Post: 06-17-2010, 11:48 PM -
Carb Help!
By GWB in forum Wrangler and CJReplies: 3Last Post: 03-12-2007, 10:04 PM -
318 carb?
By MikeB in forum Wrangler and CJReplies: 3Last Post: 08-24-2005, 08:48 PM -
carb 85 cj7 258
By Platsmith in forum Wrangler and CJReplies: 4Last Post: 09-06-2004, 04:39 AM -
Looking for a new carb
By jsharifi in forum Wrangler and CJReplies: 2Last Post: 07-20-2003, 08:00 PM
