Brake lines
wranglersport01
hey guys its been a while since ive been on here a car ended up crashing into my house so ive been dealing all that crap. my questions is do i need to get extended brake lines if im going to install a 4"suspension and 2" body lift? i would assume yes but i do not know the length in which i would need to get. also what about the speedo cable? thanks for any help
i'm looking to install the same kind of lift you are. what kit are you buying? where are you getting it?
Jeep TJ Suspension Lift
that's the one i've been looking at, seems pretty cheap and people have told me it works pretty well
Most lift kits have brake line extensions for he rear at least; that is kind of mandatory. For the front, you can re-route the hard lines to gun UNDER the frame, which should extend them enough to get by without an extension, although I prefer the extension route personally.
