1. replace ignition switch
    Is it easy to replace an ignition switch on a 91 Renegade?
    Re: replace ignition switch
    Not bad if your reffering to the electrical switch. If you are talking about the ignition tumbler(Mechanical) part, that's a different story.
    Yeh, the mechanical tumbler is bad. I was wondering if I need special tools to disasseble the steering column, or should I just replace the whole column??
    The only special tools that i can think of is a steering wheel puller and a lock plate compressor.
  1. Ignition Switch
    By Gemini79 in forum Wrangler and CJ
    Last Post: 01-29-2009, 09:27 PM
  2. Relocating the ignition switch
    By hoobness in forum Wrangler and CJ
    Last Post: 03-09-2005, 12:32 AM
  3. Ignition Switch
    By redrooster in forum Wrangler and CJ
    Last Post: 07-26-2004, 09:02 PM
  4. Where is the ignition switch located?
    By woody-wagon in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-21-2003, 04:35 PM
  5. ignition switch won't turn
Tags for this Thread
