Thread: CJ7 Carb ???
  1. Red face CJ7 Carb ???
    I have a 1986 cj 7 "project"
    Currently there is a carter-weber carb that is no good.
    Can I replace it with a Holley? Are the vacuum hoses the same?
    What kind of work am I looking at here.
    Thank You
  2. Re: CJ7 Carb ???
    No go with a Weber.
    Rubicon Rich PatriotJeepers, Inc
    05 Rubicon
    86 CJ7 ,258,T18,Scout Dana 300,Dana 44's,Lockers,Twin stick,OBA,8274 Warn winch.
    51 M100
  3. Re: CJ7 Carb ???
    If you should shop for a Weber... please make certain you shop for a Redline Weber. Not the new and unimproved POS "weber" That would be any of the DGEC series. They are trouble. I would recommend the DGEV,DGV or DGAV 32/36. Old school, proven and a real upgrade.
    That so called "weber" DGEC 34/34 will fill the crankcase with fuel. Forums are littered with the issues that unsuspecting buyers are faced with.
    But in a more direct answer to your question, Yes you could mount up the Holley...another very fine carb. I would suggest the 350 cfm although i have mounted the list #4112 two bbl. w/500 cfm but with jet modification, sweet.
    BTW the Carter BBD is a fine carb if keep clean and a kit installed each year. A simple task in itself. Got to keep the idle tubes clean though. If you were to decide to try a kit and a reaming of the idle tubes to .032 then that will make it enjoyable in itself and spend very little money at that.
  1. Ok is this carb ok?
    By muddcakedmaniac in forum Wrangler and CJ
    Last Post: 09-11-2006, 08:43 PM
  2. Carb
    By CJ7lr in forum Wrangler and CJ
    Last Post: 03-28-2006, 07:26 PM
  3. 318 carb?
    By MikeB in forum Wrangler and CJ
    Last Post: 08-24-2005, 08:48 PM
  4. 600 or 750 carb on 350
    By bryanjeep in forum Wrangler and CJ
    Last Post: 11-19-2004, 09:48 PM
  5. carb 85 cj7 258
    By Platsmith in forum Wrangler and CJ
    Last Post: 09-06-2004, 04:39 AM
