O2 sensor wiring question....
CudaJimmy
Well, someone clipped off the pigtail that connects to the back O2 sensor on my 02 TJ. I think it happened at my wifes work (police department). Comforting, huh?
ANYWAY...
I bought a new pigtail at the dealership, but all the wires are the same color. Can someone post up a picture of the pigtail so I can get the wiring correct? This is the pigtail that plugs into the BACK O2 sensor. The pigtail that's actually on the sensor, is still there.
Thanks!
These are both downstream O2 sensors since you said it's the one on the back..
OXYGEN SENSOR 1/2 DOWNSTREAM - BLACK 4 WAY
CAVCIRCUITFUNCTION1A242 18VT/OR (4.0L CALIFORNIA)OXYGEN SENSOR DOWNSTREAM HEATER RELAY OUTPUT1F142 18OR/DG (EXCEPT 4.0L CALIFORNIA)FUSED AUTOMATIC SHUT DOWN RELAY OUTPUT2Z1 18BK(4.0L CALIFORNIA)GROUND2K299 18BR/WTGROUND2K99 18BR/OR (ABS)GROUND3K4 10BK/LBSENSOR GROUND4K141 18TN/WTOXYGEN SENSOR 1/2 SIGNAL
OXYGEN SENSOR 2/2 DOWNSTREAM (4.0L CALIFORNIA/EUROPEAN III) - 4 WAY
CAVCIRCUITFUNCTION1A242 18VT/OROXYGEN SENSOR DOWNSTREAM HEATER RELAY OUTPUT2Z1 18BKGROUND3K4 20BK/LBSENSOR GROUND4K341 18TNOXYGEN SENSOR 2/2 SIGNAL
