Hope someone can help out here. I have a 05' TJ with only 24k very easy miles on it. When driving down the freeway around 60 to 70 mph the transmission will pop with a light noise into a neutral effect for a short few seconds and then own its own it will basicaly go back into gear. Very stange! Fluid is good and it shift into all gear normal. As I mentioned there has been no abuse to the transmission
Thanks
Thanks
