tj won't rev past 1500 rpm.
kcub
Hello all, I bought a 1998 Wrangler (4.0L automatic trans), that had been broke down and setting for about 9 months. The passanger side motor mount had broken at the engine and it dropped against the distributor breaking the shaft housing. I replaced the Dist, cap, rotor, plugs, and tried to crank it. Would not crank. Not getting fuel. So drop the tank and screen is stopped up from setting. Replaced screen and tried again. This time it cranked and after a few min. it idled great. Now to the problem. If i try to rev the engine it will start to missfire at about 1500 to 1800 rpm. but it will idle perfictly. I thought it might be the TPS but it checked good on my multimeter showing .1 to 5.72 ohms resistance with no noticable deadspots. There is 5.09 volts coming into the tps from the computer. I have checked for vacume leaks and found none. I cleaned the throttle-body and Idle servo. I'm in need of a new place to start looking. Please help.
I'll check that tomorrow and we'll see what it does. I thought that a bad o2 senser would make a ruff idle or rich condition, but it idles fine. Still its something to check. Thanks
No the SES light is not on. and it doesn't show any codes. I did unplug the tps while it was running and it wouldn't miss untill 2500 to 2800 rpm. I just don't know what the TPS does to the engine to know if this is important. When I unpluged the TPS I did get the 24 code.
Modes of operation:
The TPS is a variable resistor that provides the Powertrain Control Module (PCM) with an input signal (voltage) that represents throttle blade position. The sensor is connected to the throttle blade shaft. As the position of the throttle blade changes, the resistance of the TPS changes.
The PCM supplies approximately 5 volts to the TPS. The TPS output voltage (input signal to the PCM) represents the throttle blade position. The PCM receives an input signal voltage from the TPS. This will vary in an approximate range of from.25 volts at minimum throttle opening (idle), to 4.8 volts at wide open throttle. Along with inputs from other sensors, the PCM uses the TPS input to determine current engine operating conditions. In response to engine operating conditions, the PCM will adjust fuel injector pulse width and ignition timing.
As input signals to the powertrain control module (PCM) change, the PCM adjusts its response to the output devices. For example, the PCM must calculate different injector pulse width and ignition timing for idle than it does for wide open throttle (WOT)
The PCM will operate in two different modes: Open Loop and Closed Loop.
During Open Loop modes, the powertrain control module (PCM) receives input signals and responds only according to preset PCM programming. Input from the oxygen (O2S) sensors is not monitored during Open Loop modes.
During Closed Loop modes, the PCM will monitor the oxygen (O2S) sensors input. This input indicates to the PCM whether or not the calculated injector pulse width results in the ideal air-fuel ratio. This ratio is 14.7 parts air-to-1 part fuel. By monitoring the exhaust oxygen content through the O2S sensor, the PCM can fine tune the injector pulse width. This is done to achieve optimum fuel economy combined with low emission engine performance.
The fuel injection system has the following modes of operation:
  • Ignition switch ON
  • Engine start-up (crank)
  • Engine warm-up
  • Idle
  • Cruise
  • Acceleration
  • Deceleration
  • Wide open throttle (WOT)
  • Ignition switch OFF
The ignition switch On, engine start-up (crank), engine warm-up, acceleration, deceleration and wide open throttle modes are Open Loop modes. The idle and cruise modes, (with the engine at operating temperature) are Closed Loop modes.
IGNITION SWITCH (KEY-ON) MODE
This is an Open Loop mode. When the fuel system is activated by the ignition switch, the following actions occur:
  • The powertrain control module (PCM) pre-positions the Idle Air Control (IAC) motor.
  • The PCM determines atmospheric air pressure from the MAP sensor input to determine basic fuel strategy.
  • The PCM monitors the engine coolant temperature sensor input. The PCM modifies fuel strategy based on this input.
  • Intake manifold air temperature sensor input is monitored.
  • Throttle position sensor (TPS) is monitored.
  • The auto shutdown (ASD) relay is energized by the PCM for approximately three seconds.
  • The fuel pump is energized through the fuel pump relay by the PCM. The fuel pump will operate for approximately three seconds unless the engine is operating or the starter motor is engaged.
  • The O2S sensor heater element is energized via the ASD relay. The O2S sensor input is not used by the PCM to calibrate air-fuel ratio during this mode of operation.
  • The Up-shift Indicator Lamp is illuminated (manual transmission only)
ENGINE START-UP MODE
This is an Open Loop mode. The following actions occur when the starter motor is engaged.
The powertrain control module (PCM) receives inputs from:
  • Battery voltage
  • Engine coolant temperature sensor
  • Crankshaft position sensor
  • Manifold absolute pressure (MAP) sensor
  • Camshaft position sensor signal
The PCM monitors the crankshaft position sensor. If the PCM does not receive a crankshaft position sensor signal within 3 seconds of cranking the engine, it will shut down the fuel injection system.
The fuel pump is activated by the PCM through the fuel pump relay.
Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off.
The PCM determines the proper ignition timing according to input received from the crankshaft position sensor.
ENGINE WARM-UP MODE
This is an Open Loop mode. During engine warm-up, the powertrain control module (PCM) receives inputs from:
  • Battery voltage
  • Camshaft position sensor signal (in the distributor)
  • Park/neutral switch (gear indicator signal - auto. trans. only)
  • Air conditioning select signal (if equipped)
  • Air conditioning request signal (if equipped)
Based on these inputs the following occurs:
  • Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off.
  • The PCM adjusts engine idle speed through the idle air control (IAC) motor and adjusts ignition timing.
  • The PCM operates the A/C compressor clutch through the A/C compressor clutch relay. This is done if A/C has been selected by the vehicle operator and specified pressures are met at the high and low - pressure A/C switches. Refer to Group 24, Heating and Air Conditioning for additional information.
  • When engine has reached operating temperature, the PCM will begin monitoring O2S sensor input. The system will then leave the warm-up mode and go into closed loop operation.
IDLE MODE
When the engine is at operating temperature, this is a Closed Loop mode. At idle speed, the powertrain control module (PCM) receives inputs from:
  • Battery voltage
  • Battery voltage
  • Oxygen sensors
  • Power steering pressure switch (2.5L engine only)
Based on these inputs, the following occurs:
  • Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off.
  • The PCM monitors the O2S sensor input and adjusts air-fuel ratio by varying injector pulse width. It also adjusts engine idle speed through the idle air control (IAC) motor.
  • The PCM adjusts ignition timing by increasing and decreasing spark advance.
On 2.5L 4 - cylinder engines, a power steering pressure switch is used to supply an input to the PCM when steering pump pressure is high. This will raise engine speed. Refer to Power Steering Pressure Switch in this group for additional information. The 4.0L 6 - cylinder engine does not use this switch.
CRUISE MODE
When the engine is at operating temperature, this is a Closed Loop mode. At cruising speed, the powertrain control module (PCM) receives inputs from:
  • Battery voltage
  • Oxygen (O2S) sensors
  • Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then adjust the injector pulse width by turning the ground circuit to each individual injector on and off.
  • The PCM monitors the O2S sensor input and adjusts air-fuel ratio. It also adjusts engine idle speed through the idle air control (IAC) motor.
  • The PCM adjusts ignition timing by turning the ground path to the coil on and off.
  • The PCM operates the A/C compressor clutch through the clutch relay. This happens if A/C has been selected by the vehicle operator and requested by the A/C thermostat.
  • The Up-shift Indicator Lamp is operated (manual transmission only)
ACCELERATION MODE
This is an Open Loop mode. The powertrain control module (PCM) recognizes an abrupt increase in throttle position or MAP pressure as a demand for increased engine output and vehicle acceleration. The PCM increases injector pulse width in response to increased throttle opening.
DECELERATION MODE
When the engine is at operating temperature, this is an Open Loop mode. During hard deceleration, the powertrain control module (PCM) receives the following inputs.
  • Battery voltage
  • Vehicle speed sensor
If the vehicle is under hard deceleration with the proper rpm and closed throttle conditions, the PCM will ignore the oxygen sensor input signal. The PCM will enter a fuel cut-off strategy in which it will not supply a ground to the injectors. If a hard deceleration does not exist, the PCM will determine the proper injector pulse width and continue injection.
Based on the above inputs, the PCM will adjust engine idle speed through the idle air control (IAC) motor.
WIDE OPEN THROTTLE MODE
This is an Open Loop mode. During wide open throttle operation, the powertrain control module (PCM) receives the following inputs.
  • Battery voltage
During wide open throttle conditions, the following occurs:
  • Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off. The PCM ignores the oxygen sensor input signal and provides a predetermined amount of additional fuel. This is done by adjusting injector pulse width.
IGNITION SWITCH OFF MODE
When ignition switch is turned to OFF position, the PCM stops operating the injectors, ignition coil, ASD relay and fuel pump relay.
what was it that pluged your fuel screen up ? did you drain and clean out the fuel tank and replace the fuel filter. Could be just a pluged up fuel system thats starving the engine for fuel when you give it gas. I would go over the fuel system first ! drain and clean out the tank and then blow out the fuel lines and change the filter its simple and only cost you a fuel filter and time. and you know murphys law( its the last thing you check that fixes it :cry: when it should have been the first thing to be checked )
Thanks steelheadz, I printed that out for future referance. I'll get a fuel pressure gage and see if the pressure is right.
Right now WOT is 1500 rpm but the pressure was steady while it was running and when i tried to rev the motor. I will drop the tank and make sure that there is a good volumne of fuel coming out the pump. Is there a valet mode or something that could cause this?
Did I miss something, or have you had the codes checked at Autozone or wherever?
