Pump the clutch pedal about 30 times, then wait a few minutes or more and repeat if necessary. These are sealed systems (no bleeder valve)
for the yj and tj and the "air" will find its way back to the master cylinder. (air is lighter than dot fluid and pumping forces fluid in and the air out) Sounds silly, but works for every one I've ever came across.
