Thread: Advice Needed
    Advice Needed
    hey all,
    Im looking at a couple lifts at my jeep right now and im having trouble deciding on what to get. I was aiming at something near 4 inches but dont wanna spend the 600 or 700 dollars plus for the kit. How does a 2.5'' spacer lift with a 1'' body lift sound?
    Any advice is welcome
    Thanks
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    cheap way go to a junk yard find 2 sets of f150 coils adds 3 inch prob run about $125 for springs ,I'd rather do springs than spacers anyday
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    Re: Advice Needed
    Quote Originally Posted by 54cj3b View Post
    Will this work as good as a suspension lift kit?
    Sorry imma newb
    Explian please
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    springs are part of your suspention
    Re: Advice Needed
    Okay nowi understand,
    Would i have to make any modifications? like extend brake lines, or change the drive shaft. maybe lower the transmission?
    Thnks
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    may need to extend brake lines and change shocks out is about it
    this is considered a poor mans lift but works very well
  7. #7
    Re: Advice Needed
    what kinda shocks should i get?
    haha agreed.
    Here were i live on sundays the local junkyard has a special.
    Anything you can carry for 60 bucks
    haha
  8. #8
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    any shock you like but wait till springs are installed to take your measurements for shock legnth both flat and flexed out
    ranchos 5000s arent bad
  9. #9
    Re: Advice Needed
    Haha cool cool
    Well how much do you think those ranchos will cost?
  10. #10
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    bout $40. ea give or take
  11. #11
    Re: Advice Needed
    Black Diamond doesn't make bad shocks either from my experience, I'm running them right now. They also cost about $40 ea.
    '95 Wrangler Rio Grande - 2.5L 5-speed - 2" Black Diamond Lift - Carr Rota Lightbar - 4x PIAA Daylighters - Cragar 397 Series Soft 8's - 31" BFG A/T's - 4.0L Throttle Body - 3" Custom Intake w/ Speed by Spectre Conical Filter
  12. #12
    Re: Advice Needed
    One more thing,
    Any year f150? Or is it specific?
  13. #13
    Aug 2009
    Evergreen,Colorado
    1,520
    Re: Advice Needed
    I always used early 80s to mid 80s since springs were a little taller 90s and up are a tad shorter but will work just use same year front and rear so you dont droop
  14. #14
    Re: Advice Needed
    Using F150 coils could be an issue. first, you have different spring rate in teh front and rear, your going to put a lot stiffer (as in WAY stiffer) spring in the rear. the ride quality will be horrible, boarder line dangerous if the road conditions are right.
    Second, your front and rear springs also have different spring heights. if you take 4 front coils from a F150 and put them at each corner of your tj, the rear of your jeep is going to sit a couple inches higher. this in turn will cause some steering issues since you changed you caster angle.
    If the coils yield a 3" lift, you will be pretty much at the limit of your factory control arms as well. you still will have to buy springs, address the driveshaft angles, steering, brakes.
    The reason why kits cost so much is because
    1. the product is engineered to work safely
    2. it's completeness.
    I suggest the BDS Budget spring kit. should get about 2" of lift, perfect for a set of 33's
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  15. #15
    Re: Advice Needed
    Quote Originally Posted by jps4jeep View Post
    Agreed,
    I rather spend money and buy something i know will work.
    Ill look into the BDS jps4jeep, thanks for all the help guys..
    Hey jps4jeep type of tire?
  16. Re: Advice Needed
    If you would like, PM me and give the specifics of your Jeep and what you want. I will see what I can get and give you prices.
  17. #17
    May 2009
    Chattanooga Tennessee
    636
    Re: Advice Needed
    You can always put your factory springs in the rear for a 3-3.5" lift and buy front lift springs the same height. I personally HATE BDS lifts but that is my opinion. Their YJ junk flexes like a tractor. Maybe their TJ kit is better. Rough Country is decent but if you plan on wheeling it and keeping it for a while invest in a Rusty's or Rubicon Express kit. Well worth the price and includes most everything even brake lines.
  1. 4.2l to 4.0 swap? Your advice needed :).
    By wannagojeepN in forum Wrangler and CJ
    Last Post: 06-09-2008, 09:53 AM
  2. Paint gun advice needed
    By Junkpile in forum General Chat
    Last Post: 05-25-2005, 07:26 PM
  3. TJ lift advice needed
    By Junkpile in forum Wrangler and CJ
    Last Post: 12-28-2004, 01:08 PM
  4. Advice needed
    By 1981CJ5 in forum Wrangler and CJ
    Last Post: 02-25-2004, 04:20 PM
  5. advice needed for new project
    By X_Factor in forum Wrangler and CJ
    Last Post: 01-22-2004, 04:45 PM
