Thread: 2003 Saharah Jumps out of 4WL
02-17-2010, 11:21 PM #1
2003 Automatic Saharah (daughter's vehicle) jumps out of 4WL many times before it will finally stay put. It has a 2.5" body lift. Someone told me there was an extension or adapter that I needed to install. Anyone have specific info on this?
thanks,
dg
02-18-2010, 07:29 AM #2
Re: 2003 Saharah Jumps out of 4WL
Look here this may give you a idea on what to look for.
http://www.roughcountry.com/install/tjcombo.pdf
Look under (POST INSTALLATION INSTRUCTIONS)
Check the transfer case shifter to see if it will move to4L. If
not, the linkage will need adjusting. Place the shifter in 4L,
loosen adjustment bolt and push the linkage forward until it
stops. Now re-tighten adjustment bolt. See Photo 1. Check to
be sure 4WD works properly.
02-19-2010, 11:28 AM Thread Starter #3
Team Twisted,
Thanks very much. I'm going to do this adjustment this weekend. I really appreciate the reply.
dg
02-20-2010, 08:54 AM #4
Yes, I also installed a 2.5 inch lift in my 2004 Wrangler and had problems with my 4wd. the adjustment only takes 5 seconds to do and everything will be good to go!
Jeep......Its not a following.............Its a Cult!
JEEP 0 IIIII 0
1998 Cherokee 4L jumps from 210 to 260 very fast
By rpfelder69 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 3Last Post: 06-27-2008, 12:42 AM -
2003 TJ for sale
By exjay33 in forum Items for Sale, Trade, or Give AwayReplies: 0Last Post: 09-06-2004, 09:15 AM -
How to get better gas mileage with a 2003 TJ?
By MIKE2003TJ in forum Wrangler and CJReplies: 10Last Post: 03-25-2004, 03:40 PM -
2003 Suspension Kit
By berettajeep in forum General ChatReplies: 1Last Post: 07-20-2003, 08:00 PM -
2003 Sport in need of a 2003 suspension lift
By RAVEN13xxx in forum General ChatReplies: 5Last Post: 07-20-2003, 08:00 PM
