Rear Tire Rubs
Off-Air
On my 2005 Wrangler Unlimited (4" lift) I was rolling on stock rims with BFG MT's 33x10.5 R15. I changed tires to Goodyear Duratrac 33x12.5 R15. Now my tire is rubbing in the rear inside. Does anyone know if Pro Comp Xtreme Alloy Series 7069 with a 3.75 Backspace will stop the rubbing? The offset on these wheels is 19mm. What is the offset of stock rims?:???:
your probably rubbing in the front too.
get good wheel spacer and make sure that they are torqued down.
Tire shops do not like wheel spacers, but the solve the problem of rubbing in rear.
Good Luck
