My passing gear doesn't seem to kick in when I step on the gas, it just remains at the same rpm and slowly accelerates. The transmission kick down cable is attached to the throttle, could this be a vacuum line issue?
i am not sure on the newer wranglers. i have never had to adjust my wife's 93. i know how to do the cherokee but i don't know if yours is the same as those are. do you have a cable or a rod?
IF there is an adjuster on the cable, there would be a clip that needs to be disengaged from the housing. After adjusting it to the proper position, snap the clip back in and road test it.
