    Oct 2010
    Pensacola, Florida
    113
    yj wont stay running when put in gear
    i have a 88 yj with 258 i just put the carb (weber 32/36) back on with new adapter plates. now it cranks fine and idles fine but as soon as i put it in gear (tf 999 auto) it starts running bad and dies before i can even move. after i let it warm up for 20 min or so and try a few times it eventually starts and does fine. any ideas?
    a man gotta have a code
    Re: yj wont stay running when put in gear
    Sound slike your choke isn't properly adjusted. Turn it alittle more towards closed, just a little at a time, and try it.
    Yes, I did do that on purpose
    Yes, I can fix it
  3. Re: yj wont stay running when put in gear
    Doesn't sound *quite* like the problem I had, but I'd check the fuel pump and/or filter, see that you're getting enough fuel through?
    I'm no expert, just guessing from my experiences.
    Jeep Wrangler '92 YJ
  1. Idleing problems..Wont stay running
    By BAM4x4 in forum Wrangler and CJ
    Last Post: 11-18-2014, 05:03 PM
  2. '75 CJ5 won't stay running
    By nvmycj in forum Wrangler and CJ
    Last Post: 09-04-2010, 01:56 AM
  3. 89 yj wont stay running...
    By rob3307 in forum Wrangler and CJ
    Last Post: 09-13-2008, 05:35 PM
  4. starts but wont stay running
    By blown XJ in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-07-2008, 10:17 PM
  5. ZJ Won't Stay Running
    By orangeamc13 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-12-2006, 03:33 AM
