1. Sputtering at speeds over 40
    I recently purchased a 1997 jeep wrangler se, 4 cyl, 4 inch lift, 33 inch tires. I know that the clutch needs to be replaced but when i drive it over 40 mph it starts sputtering and does not really want to accelerate anymore. i dont know if its the catalitic converter or what? Any advise anyone could give me would be appreciated! Thanks in advance!!
    Re: Sputtering at speeds over 40
    You can test the converter by either loosening the exhaust where the manifold meets the pipe or remove the o2 sensor in front of the cat. If it runs better like that then you know its the converter.
    Yes, I did do that on purpose
    Yes, I can fix it
    Feb 2009
    Dayton Ohio Area
    5,169
    Likely the TPS or CPS. Also when is the last time you changed the plugs?
    You know, i really have no work history for the jeep so i think its safe to say its been a long time. Im also not very mechanically inclined, what is the TPS or CPS? Thank you both for replying. How much does it cost to replace these parts mentioned? I hope i didnt invest in a cash pit.
    Are the tires to big? Did it ever run good with 33" I really would not think you could do much over 40 mph with 2.4 L and 33" tires not with factory gears. but I could be wrong
    Quote Originally Posted by jimi003
    Is it a sputtering or a back fire? Any jumping when accelerating? Just asking because sputtering does not usually cause a vehicle to stop accelerating.
    Go to your local auto parts grab a Haynes Manuel. Use that to help cover your bases.
  7. #7
    Feb 2009
    Dayton Ohio Area
    5,169
    Quote Originally Posted by jimi003 View Post
    TPS – Throttle Position Sensor - Indicates the Throttle body butterfly position to teh PCM
    CPS – Crank Position Sensor - Indicates the crank's position to the PCM and the revolutions.
    Both common fail parts and not sure on the price but not expensive.
    If you don't have the work history I'd first fix the clutch then change the plugs wires , distributor cap and rotor. All for app $60 Then see if it still has the issue. These are a part of a normal tune up people do about every 30 to 40K mi.
  8. #8
    Along with the common tune-up, I'd remove the throttle body from the intake manifold, remove the sensors, and give the throttle body a good bench cleaning. It's easy to remove. Clean with carb cleaner and an old toothbrush.
  1. Shaking at high speeds
    By 01jeepgc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-10-2010, 12:46 PM
  2. at HWY speeds steering shakes real bad
    By andyruiz in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-25-2010, 05:51 PM
  3. 4 Hi engaged at Highway speeds... Opinions?
    By chinard in forum Wrangler and CJ
    Last Post: 10-09-2003, 06:58 PM
  4. how to get more power at highway speeds
    By Sacredgroove in forum Wrangler and CJ
    Last Post: 09-25-2003, 08:26 AM
  5. Cherokee stalls at highway speeds
    By Tug-n-pull in forum Cherokee, Commander, Wagoneer and Liberty
