87 wrangler 4.2
smalloy24
Hi every one I have replaced my clutch 3 times allready. The issue is that the slave cylinder/throwoit bering is making noise. Also I would like to do a transmission swap to the ax15 I think is the one that will fit. My revese sync is out and 4/5 gear rattles and clunkes. When clutch petal is pressed you can here a rubbing noise
Were would be the best place to find a used one at here in Bossier ther is not many jeeps in junk yards
