wheel spacers
I have 35/12.5/15's on my 93.. If you cut the wheel all the way it'll rub your leaf springs in the front. I believe it will also rub the rear inside part of your wheel well. I didn't have as much trouble with my 33's as I do with my 35's. You might be all set if you don't mind having a larger turning radius. Spacers wouldn't hurt though. Hope this helps!
Thanks for all the help. I was thinking they would fit just wanted some more input before I actually mounted them.
