jeep shutting off
probably because the fuel pick up sucks up air instead of fuel? or your carb is already a little low and the fuel in the bowl is sloshing away form the jets and you are running out of fuel on that turn. maybe your fuel sender is wrong and you are closer to empty then you think?
