Grease nipple locations
Midnightsecurity
Hey all, on my 99TJ I'm blown away at how little grease locations there are !! I have only 6 on the front end and can't find anymore anywhere, am I missing any??
You aren't missing any assuming you have stock parts. Once you start upgrading things they will start having grease fittings.
LOL Nipples...
Thanks, I needed that.
just so you know for future reference, they are tech. called Zerk Fittings... Next time you type nipple, there better be some boobs attached to those nipples (*EDIT* female Boobs)
a little FYI also, non-grease fitting u-joints are stronger than ones with grease fittings, since there is not bore accross the center of the trunions to provied the grease, they are just simply stronger. this does not mean a non-grease fitting U-joint can't be serviced, but you will have to putt the joint out and remove the caps, just a little dollup of grease in there and put back together.
