1. the jeep tick,tick,tick.
    Was talking to some one last night about the tick noise that the jeeps make as they get older, his response was that it is caused by a cracked manifold. Any opinions on that.
    Re: the jeep tick,tick,tick.
    i can vouch for the manifold issue it is pretty common,
    ex. the ford 302ci as soon as u drive it off the lot it will have a tick in the exaust caused by a pin hole in the manifold, i would assume jeeps will eventually do the same.
    myself i put a header on my jeep so dont have that issue...yet
    a way to check is spray soapy water on the manifold (when its cold) and look for bubbles when u start it up
    if not i would check lifters and such
    hope it helps
    I broke it.....
    Fixed it......
    Broke something else.....
    finding all the flaws one break at a time
    Quote Originally Posted by gennybro
    Intake or exhaust manifold? If its intake just spray it with starting fluid and listen for an increase in idle. That's will tell u if there any leaks. I don't know any tricks for the exhaust expect for the one mentioned above
    Most early 90 models exhaust manifolds did have a problem in the collector tubes welds. This problem was most prevalent in the 4.2 and the 4.0L factory exhaust. I haven't found any Electronic Service bulletin on 2.5L exhaust leaks but that doesn't mean there isn't one. I do know of only 1 97 2.5L that has that tick.
    blatant jokessubliminal sarcasmsexual innuendo
    Dec 2010
    California
    514
    On my 2002, the tick, tick, tick occurs when the AC is on. The tick is coming from a relay that cycles the AC on and off at idle.
  6. Quote Originally Posted by Utah_jeepster
    Ya my 97tj with the 2.5 had a crack in the manifold It Was just really loud and sounded kind of bad but there are very lax Emission laws in Nebraska so I drove it like that for like a year and finnaly paid 400 for it to get fixed
  7. #7
    The most common tick for your year and engine is broken exhaust manifold studs, the front stud and the rear stud commonly break. Inspect the exhaust manifold and you'll likely see holes where the manifold studs should be.
    If your tick is noisy lifters, try adding a half quart of ATF to the engine oil.
  8. #8
    Thanks for the info guys.
  1. valve tick noise or lifter noise 97 jeep grand cherokee
    By Tazdman in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-13-2011, 07:00 PM
  2. Engine Tick
    By cherokeebob1966 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-01-2008, 12:58 AM
  3. tick, tick, tick.....grrr!
    By dingus in forum Wrangler and CJ
