Thread: Good buy?
  1. Good buy?
    And how much work would it be to get it to fit my 97 wrangler?
    Re: Good buy?
    Quote Originally Posted by MattMayTJ View Post
    The first question is, is this Dana 44 an Aluminum housing. Many of the grand Cherokee Dana 44's were a aluminum housing with steel tubes if it is, pass on this axle. They are weaker than a Dana 35.
    If its an all steel set-up then it shouldn't be anything too difficult that a back yard mechanic shouldn't be able to do.
    Since you will be going to a rear disc set-up, you might purchase a manual proportioning valve, since your front disc/rear drum proportioning valve will still set the brake bias to the front. I have seen several attempts at putting a newer LJ proportioning valve with some fabrication necessary. The Grands and regular Cherokee's with 4 wheel disc will not work because of the weight difference.
    blatant jokessubliminal sarcasmsexual innuendo
    So I need to ask him if it's an all steel set up before I even think about looking at it?
    May 2009
    Chattanooga Tennessee
    636
    Re: Good buy?
    It also has a different bolt pattern and the GC 44 uses different lockers than a standard 44 so be aware the aftermarket is very slim for this axle. It's also c-clipped but being a WJ it shouldn't have the aluminum center section. If you can get it for about half that and swap your front hubs and brakes and buy new wheels you'd be good. Lot of work for not a very desirable axle. If it was a XJ or TJ 44 I'd say go for it but not one from a grand.
    Re: Good buy?
    I had a 99 grand cherikee and the wheels were the same as my YJ. I had them on it for a while. In my opinion, If you don't plan to upgrade it any more than it is, Then go for it. Even tho it's not a highly desirable axle, It's a lot better than what you've got. If you can talk him down on price because it's not the most desirable axle, Then gooder for you.
    If you want to drive a sports car, Buy a mustang.
    Re: Good buy?
    Quote Originally Posted by steady.foot View Post
    No you didn't or no they weren't.
    99 and on grands are all 5 on 5 bolt pattern, same as the current JK. All YJs, TJs, XJs and 93-98 grands (ZJs) are 5 on 4.5 bolt pattern.
    The aluminum D44 or D44a rear from the grands is not worth it's weight in scrap metal. The axle is prone to gear deflection due to the different metals and different rates of heat transfer, add a locker and it gets worse. The ZJ D44a and I think 99-2000 WJ D44a were all C-clip axles. The factory "locker" is not a locker, it is a LSD that is about a sstrong as a toothpick.
    in closing, not worth $200
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  7. #7
    Alright thanks for all your input. Glade I could ask u guys about it I just assumed all Dana 44 where the same
  8. #8
    Re: Good buy?
    Quote Originally Posted by jps4jeep View Post
    Yup. Your right. My memory is playing tricks with me. The GC that i had was a 97 not a 99. It was another vehicle that i had that was a 99. In that case, The 99 axle wouldn't be a good choice.
  9. #9
    Re: Good buy?
    All is forgiven, go in peace.
    -Johnny-
  1. Good to be here!
    By Turbogus in forum General Chat
    Last Post: 08-10-2012, 06:47 PM
  2. Is this a good buy?
    By Hazrider in forum Wrangler and CJ
    Last Post: 07-30-2006, 10:44 AM
  3. This is a good one...
    By Craig in forum General Chat
    Last Post: 02-03-2004, 05:24 AM
  4. Its no good... no good i say...
    By berettajeep in forum Wrangler and CJ
  5. good cj7
    By duff in forum Items for Sale, Trade, or Give Away
