Auto Transmission Cooler?
Sahara707
Who's running an automatic transmission cooler? 2000 TJ, 35" tires, Dana 44 with 4.88's. Just finishing the build so it hasn't been on the trails yet. So do you think I need to add the cooler. Thanks!
2001 TJ, 33 tires, Dana 44 4:56 gears Stock 3 speed transmission, deep transmission pan with a 1/2 ton ford aux transmission cooler connected to the "V" bars up front.
The number 1 killer of automatics is heat, so the better the cooling the longer it lasts!!!
