Page 79 of 82 First ... 29697778798081 ... Last
  1. #1561
    Feb 2009
    Dayton Ohio Area
    5,398
    Re: What did you do to your Jeep today?
    SouthTj How did you make out?
    Regards,
    JPNinPA
    Sent using TapTalk
  2. #1562
    Feb 2009
    Dayton Ohio Area
    5,398
    Changed the oil
    Changed the trans fluid. Trying RedLine
    Changed transfer case fluid
    Plan
    Change the rest of the fluids
    Power steering
    Front and rear differentials
    Bleed clutch full change.
    Bleed brakes full change. + new extended brake lines.
    Regards,
    JPNinPA
    Sent using TapTalk
  3. #1563
    Feb 2009
    Dayton Ohio Area
    5,398
    Check
    Check
    Check
    Only differentials left. Waiting for new seals to arrive.
    Regards,
    JPNinPA
    Sent using TapTalk
  4. #1564
    Regards,
    JPNinPA
    Sent using TapTalk
    I've been on vacation with very little wifi and just saw the video you posted about adjusting the sensor. I did not know that it needed any adjusting so I'll check that video out when I get home. No time to watch at work right now.
  5. #1565
    Feb 2009
    Dayton Ohio Area
    5,398
    New JKS front track bar
    New grade 8 tight fitting axel side bolt.
    New front shocks.
    New Crown HD STeeR Grand Cherokee
    R1 steering upgrade.
    New steering stabilizer.
    Next week:
    Rear shocks.
    Rear Adj track bar.
    TB Relocation bracket.
    Alignment
  6. #1566
    Nov 2011
    Lee County Florida
    1,724
    New front shocks.
    Next week:
    Rear shocks.
    Rear Adj track bar.
    Alignment
    Right on brother!
    Sent from my SM-G950U using Tapatalk
  7. #1567
    Dec 1999
    Virginia Beach VA
    8,041
    The angry sparrows are back, so I ordered some Spicer 5-1310-1X U-Joints for my rear driveshaft. I like that these can be easily greased, instead of the traditional kind that have the nipple on the cross.
    What did you do to your Jeep today?-61z5fammbyl._sl1500_.jpgSpicer 5-1310-1X U-Joint
    My 2005 Wrangler Build Thread
  8. #1568
    Feb 2009
    Dayton Ohio Area
    5,398
    Quote Originally Posted by TerryMason View Post
    I watched a video explaining D30, D44 and D60 axels. He covered a lot more in the vid. One was mentioning joints that don't use needle bearings. Not sure what the advantage is or where they use them but something to look into.
    Second is this one you had replaced before and have you been greasing them.? If so you got to ask why this failing. If it's one never changed before... Well maybe it was time. Spicer offers joint packs that has all the joints for your vehicle. Not sure if they are the greasy kebab ones.
    Luck!
    Regards,
    JPNinPA
    Sent using TapTalk
  9. #1569
    I can see where that would be a benefit. The only way to grease one of the u-joints on my old ford truck's front driveshaft is to remove the other end of the driveshaft so you can orientate the joint's fitting into an accessible position. Needless to say that joint doesn't get greased as often as the others
  10. #1570
    Feb 2009
    Dayton Ohio Area
    5,398
    Replaced monster cat back with new monster cat back. Why? I got ~13 years before this one rotted beyond repair.
    Strange the pipe and exhaust rotted at the connections. Muffler and tailpipe extension. Pipe itself was fine and exhaust was fine. Wonder if the corrosion was a galvanic driven.
    New pipe is 2 pieces and thicker stainless. It doesn’t look like T202 the old one was made of. The T202 formed a black coating after some use. The tail pipe ends 13 inches under the vehicle and the with the tip roughly 8-10 in under the jeep. I ditched that tip and added a 13” angle cut turn down. This way the exhaust gas isn’t billowing under the jeep when wheeling and filling the cabin with fumes.
    Muffler was not highly polished. Not that i care but is advertised that way.
  11. #1571
    Dec 1999
    Virginia Beach VA
    8,041
    I previously had problems with the front driveshaft - I built it with non greasable ujoints, and those wore out so I used these greasable ones. This time around it's the rear shaft (I believe). My rear shaft is actually a cut down cherokee front shaft, so it's got a cardian joint in it, and I run a SYE.
    Having said that, I have not been greasing the joints the way I should. I may roll around with the grease gun and lube everything up next week.
  12. #1572
    I hit a speed bump at the mall today.
  13. #1573
    Feb 2009
    Dayton Ohio Area
    5,398
    Nice curb hop!
    Outdoor malls are the best!
    Your shine could be seen by more as you tool around!
  14. #1574
    Nov 2011
    Lee County Florida
    1,724
    Quote Originally Posted by dwillys View Post
    That thing is awesome!
  15. Re: What did you do to your Jeep today?
    Made a video of our current setup including our under seat 10 inch powered subwoofer (https://amzn.to/2LMZpB9) for our 2015 Jeep Wrangler. We put the sub under the drivers seat and couldn't be happier!
  16. #1576
    Dec 1999
    Virginia Beach VA
    8,041
    Quote Originally Posted by Jeepinaround View Post
    That's a neat subwoofer - I've never seen one like that - does it make much bass?
    I did one a couple of years ago inside of my rear seat. It sounds great, but is quite a bit of work (and cost 4x as much)
    https://www.jeepz.com/forum/accessor...rear-seat.html (Subwoofer inside of a Jeep Wrangler rear seat)
  17. #1577
    Feb 2009
    Dayton Ohio Area
    5,398
    Kenwood has been making powered subs for years. I have gen 1 under my back seat. Here is a link to the current gen. Works great and has a control I mounted behind the shifter on the bezel.
    Here is what I have:
    Current -shop around for price.
    ~11x8x3
    https://www.crutchfield.com/S-jZO1WW...-KSC-SW11.html
    ~13x10x3
    https://www.crutchfield.com/p_113KSC...-KSC-PSW8.html
    P.S. If mounted under your seat.... Well the vibration may become annoying.....or you might like it.... Anyway it will loosen you up like prunes and olestra. Just hope you don't get DW.
    Butt Dino may be out of calibration.
    Regards,
    JPNinPA
    Sent using TapTalk
  18. Re: What did you do to your Jeep today?
    Added Jeep wave stickers on the side mirrors! Super fun!
  19. #1579
    Dec 1999
    Virginia Beach VA
    8,041
    Touched up the front bumper with a new coat of gloss black
    Sent from my Nexus 5X using Jeepz.com mobile app
  20. #1580
    Feb 2009
    Dayton Ohio Area
    5,398
    Nice What did you do to your Jeep today?
  1. Today I'm a new Jeep owner!
    By warden37 in forum Wrangler and CJ
    Last Post: 12-27-2010, 09:51 AM
  2. My Jeep got stolen today...
    By 06TJ in forum General Chat
    Last Post: 12-19-2009, 01:58 PM
  3. Saw my first Jeep today...
    By Mr.Bones in forum General Chat
    Last Post: 10-22-2008, 01:12 PM
  4. Got Jeep baptised today
    By Deerhunter30 in forum General Chat
    Last Post: 10-13-2004, 10:54 PM
  5. My jeep kicked a$$ today!!!!!
    By Jeepster05 in forum General Chat
