Page 81 of 83 First ... 31717980818283 Last
  1. #1601
    Re: What did you do to your Jeep today?
    @jeepinaround...good tip for extra storage. Took this to another level by adding an organizer for the deep jeep center console. What did you do to your Jeep today?-img_20191125_094058_edit.pngWhat did you do to your Jeep today?-img_20191125_094106_edit.pngWhat did you do to your Jeep today?-img_20191123_153429.jpgWhat did you do to your Jeep today?-img_20191123_153457.jpg
  2. Re: What did you do to your Jeep today?
    We added a thick steel bumper to our jeep JK - heres how we did it! Cheers and Happy Thanksgiving Jeep Fam!
  3. Re: What did you do to your Jeep today?
    New distributor cap & rotor, plugs & wires, and an exhaust donut.
    Now, it's turkey time !
  4. Re: What did you do to your Jeep today?
    In case anyone installed a dv8 tire carrier or did a spare tire delete, here is a cool way to wire the third brake light (and add a strober) + retain a license plate light !
  5. Re: What did you do to your Jeep today?
    What's up Jeep fam! Made a video showing off glass upper window sliders for the Jeep TJ, from Bestop. Mostly positives but a couple things you should know before pulling the trigger. Really hope this is helpful! Cheers and Happy Holidays!
  6. #1606
  7. #1607
    Quote Originally Posted by aggreX View Post
    Hi. Where did you find these products? Thanks.
  8. Re: What did you do to your Jeep today?
    Made a video showing my 5 favorite super cheap "mods" to the rig each around 10$. Hope this gets some wheels turnin' for the jeep family! Cheers!
  9. #1609
    Feb 2009
    Dayton Ohio Area
    5,540
  10. #1610
    Dec 1999
    Virginia Beach VA
    8,061
    Hopefully these naked rear eliminates the other hacked rear.
    Hey, this is a family friendly site!
    My 2005 Wrangler Build Thread
  11. Re: What did you do to your Jeep today?
    Quote Originally Posted by TerryMason View Post
    Sent from my SM-N960U using Jeepz.com mobile app
  12. #1612
    Feb 2009
    Dayton Ohio Area
    5,540
    How wide are those tires and how wide is the rim?
  13. #1613
    Quote Originally Posted by sprkeng View Post
    Amazon has several venders for similar/same product. Shop around as the price ranges from $10-12 Have fun! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  14. Re: What did you do to your Jeep today?
  15. Re: What did you do to your Jeep today?
    Finally found fully plug and play Halo LED headlights for the JK and wanted to share the full install video + night clips. I have seen many people asking for "best LED headlights," and I hope this video answers a lot of questions as well as shows you how to properly align your headlights. Cheers jeep fam!
  16. #1616
    Dec 1999
    Virginia Beach VA
    8,061
    Quote Originally Posted by Jeepinaround View Post
    Those look like a pretty easy install - good work.
  17. Re: What did you do to your Jeep today?
    What's up jeep fam! On today's episode, we show you how to replace the pesky shift indicator light on your Automatic Jeep Wrangler JK with a longer lasting and brighter LED Unit! We also announce the winner of our second giveaway, of LED headlights + LED spot lights! Be sure to check out the episode, found right here! https://youtu.be/RWI91yHPJio Cheers Jeep family!
  18. Re: What did you do to your Jeep today?
    Wanted to make a video talking about our path to running 35 inch tires on our 2001 Jeep TJ 4.0 w/ factory 3.73 gears and manual transmission. There is a lot of information on the web regarding what needs to be upgraded to run 35s, and often times, this information is misleading. In this episode, I show you exactly what I did to run 35 inch tires on a SUPER budget. So far, it has been suiting my needs perfectly, although I understand that this would be less than ideal for many extreme wheelers. We absolutely love the way we got the job done and would do it again in a heart beat. Thank you for watching and please reach out if you have any questions at all!
    https://youtu.be/oHvydmHxhiQ
  19. #1619
    Feb 2009
    Dayton Ohio Area
    5,540
    Your link is messed up
    BTW
    Intake and exhaust will not improve power or efficiency on the 4.0. Placebo effect. The PCM relearns it within 500 mi.
    The regearing is to gain back high gear in auto trans. Even in manual. Are you able to pass or pull a incline and hold speed at or above 65mph in top (5th) gear? Auto trans lose high gear and cannot maintain highway speeds.
    Normal driving should occur between 2250 and 3000 RPM. This is the max efficiency for the engine without lugging. Lugging or loading the engine (below 2250 rpm) over a long time results in engine damage.
    A lot of engineering went into this chart. I’d follow it.
    What did you do to your Jeep today?-img_0769.jpg from Quadratec.com
    Front axels are often smaller than a D44. This means the ring gear and teeth are thinner. Same for the shafts. Hammering the gas in 4L 1st or 2nd gear is what twists the shaft or breaks ring gears. So light wheeling and no 4x4 burnouts, or hammering the skinny pedal allows the shafts and gearing to last.
    Regardless larger heavier tires increases stopping distances. And anything adding weight. Height may make a difference as well in some cases. So, I wouldn’t say larger brakes are not needed.
    When hot likelihood of brake fade is what to consider. Also, descending steep and lengthy inclines wheeling.
    What you did may fit your style of wheeling but there are many other levels that need consideration.
    Q:
    Did you do any of this because you didn’t mention
    1) lengthen your brake lines
    2) lengthen Bump stops
    3) lengthening track bar
    4) aligning after lift
    5) shocks?
    6) extended sway bat links (10 deg above level)
    Good luck with your new setup.
  20. Re: What did you do to your Jeep today?
    Installed some crazy bright led fog lights which also have a daytime running light feature. They light up when the ignition is switched on and can still be controlled by the factory switch. Love the increase in light at night!
  1. Today I'm a new Jeep owner!
    By warden37 in forum Wrangler and CJ
    Last Post: 12-27-2010, 09:51 AM
  2. My Jeep got stolen today...
    By 06TJ in forum General Chat
    Last Post: 12-19-2009, 01:58 PM
  3. Saw my first Jeep today...
    By Mr.Bones in forum General Chat
    Last Post: 10-22-2008, 01:12 PM
  4. Got Jeep baptised today
    By Deerhunter30 in forum General Chat
    Last Post: 10-13-2004, 10:54 PM
  5. My jeep kicked a$$ today!!!!!
    By Jeepster05 in forum General Chat
