Page 84 of 96 First ... 3474828384858694 ... Last
  1. #1661
    Re: What did you do to your Jeep today?
    The wrangler is back in Colorado. It made the drive fine in temps below 10 degrees and snowing
    03 rhd tj
  2. Re: What did you do to your Jeep today?
    New warn winch, can also fit it to the rear. Stored in a handy container in the jeep. Still can not upload pics, even with a new lap top, what's up with that ?
    Needs to go yonder.
  3. Re: What did you do to your Jeep today?
    So why can I not post pics? I am not happy.
    Needs to go yonder.
  4. #1664
    that is weird. do the picture symbols show up, or its blank?
    the symbol doesn't show up for me but i know about where it is so i just hover over till till i find it
    03 rhd tj
  5. #1665
    Dec 1999
    Virginia Beach VA
    8,415
    Quote Originally Posted by Gennybro View Post
    I just wrote a quick guide on how to upload photos - How to upload photos to Jeepz.com
    Take a look at it and reply to the thread if you have any problems. If I had to guess, I'd bet that the little window that pops up (i.e. the popup window) is being blocked by your browser.
  6. Re: What did you do to your Jeep today?
    So why is my post about uploading photos not here, when on my profile it has my post listed, strange indeed .
    Needs to go yonder.
  7. #1667
    Feb 2009
    Dayton Ohio Area
    6,768
    Its like an entire day of posts went poof.
    Its the post poof caper.
  8. Re: What did you do to your Jeep today?
    That's terrrible ! How well I ever be able to post pics if Terry does not have all the technical information I posted. Oh goodness this is terrible.
    Needs to go yonder.
  9. #1669
    Had some fun today!What did you do to your Jeep today?-20220202_163119.jpegWhat did you do to your Jeep today?-20220202_163106.jpegWhat did you do to your Jeep today?-20220202_163057.jpeg
    Sent from my SM-G781U using Jeepz.com mobile app
    Wind therapy is the best therapy...
  10. #1670
    going to get the tj this weekend. meeting my son in Lubbock or Amarillo and he is taking the Mazda back with him and we are taking the tj home with us. he said he cannot afford to drive it on e3 pay in the winter. i told him that is fine, we will swap back when summer gets here.
    plus, i found a two inch lift for cheap because a local guy swapped to a four inch
    03 rhd tj
  11. #1671
    holy cow. i don't what happened but this jeep is in terrible shape now. its going to take some work to get it back to a nice jeep. something is wrong in the driveline now, bad u-joint or bent drive shaft, i don't know yet. it vibrates from 5 mph up to highway speeds. it was a long long drive from lubbock back to corpus with it vibrating so bad you couldn't use the mirrors. i found that at 72mph it vibrated to least so that is what i drove at to make the 10 hour drive. it got between 13 and 16 mpg depending on using overdrive and if there was a headwind.
    03 rhd tj
  12. #1672
    Feb 2009
    Dayton Ohio Area
    6,768
    Check it all. Tre, ball joints control arm bushings… it was rolled
    Check the round ads square of the wheels axel housing straight…
  13. #1673
    it wasn't vibrating when he took it after christmas though. i drove it all over before he took it and everything was fine. i am going to start easy and work back though. check the u-joints and the driveshafts first. since the transmission cross member has a big bend in it now, maybe he also hit the driveshaft on whatever they were going over.
    i tried to look at the wheels to see if they were spinning true and i didn't see any issues but i could only see the back. i think its related to the back though because when we would go through small dips in the road and the back springs would compress a little, the vibes got worse. it made me think of when a lift is put on but the trans and rear diff aren't lined up properly and you need to shim the back and lower the transmission crossmember.
    i will start messing with it sometime. i have to move the washer and dryer from the front house to the garage and cap all the lines going to the house because we are knocking it down to put another one up. i imagine it will be slow going on the jeep
    03 rhd tj
  14. Re: What did you do to your Jeep today?
    I got a warn winch I can use on the front or the back of the jeep. Got a bikini top, got really kick as grip tires. I is ready Baby. Wish I could up load pics from my laptop.
    Needs to go yonder.
  15. #1675
    Apr 2003
    Pembroke Pines, FL
    366
    Installed a set of next venture skid plates on my 392. Needed some persuasion and had one wrong part, but not too bad so far. Have to see how bad the squeaks and rattles are.
    Sent from my iPad using Jeepz.com mobile app
  16. #1676
    Turns out it's the ujoint nearest to the e trans output
    03 rhd tj
  17. #1677
    Got two new 1310 spicer u-joints to put on. But, for some dumb reason I didn't block the wheels when I backed the jeep onto the ramps so when I asked my son to pull the ebrake, since the trans was disconnected, the jeep rolled off the ramps and crushed me under the fuel tank skid plate. I was on my back, kind of leaning left when it started to roll.
    so I tried to yank myself out of the way of the diff and was on my left side when the jeep came down and pushed my shoulders together.
    The emergency room said unbelievably nothing is broken but since it's a crush injury, tomorrow is going to be really bad, pain wise.
    I thought my left collar bone and shoulder snapped because of the horrible noise it made. It sounded like when a dog is chewing chicken bones, that snapping sound. But, luckily nothing broke
    So, moral of the story. Put the wheel chocks in place. Don't forget or get complacent and think nothing will happen. This could have been bad with broken shoulder and collar bone probably being the least of the bad things
    03 rhd tj
  18. #1678
    Dec 1999
    Virginia Beach VA
    8,415
    Man, that is horrible! I'm glad that you're OKish.
  19. #1679
    Thanks. It's getting more sore as I sit so tomorrow should be grand, ha ha ha
    03 rhd tj
  20. #1680
    Feb 2009
    Dayton Ohio Area
    6,768
    Holy !!! You are lucky. ^^ agree^^ glad you are ok ish
  1. Today I'm a new Jeep owner!
    By warden37 in forum Wrangler and CJ
    Last Post: 12-27-2010, 09:51 AM
  2. My Jeep got stolen today...
    By 06TJ in forum General Chat
    Last Post: 12-19-2009, 01:58 PM
  3. Saw my first Jeep today...
    By Mr.Bones in forum General Chat
    Last Post: 10-22-2008, 01:12 PM
  4. Got Jeep baptised today
    By Deerhunter30 in forum General Chat
    Last Post: 10-13-2004, 10:54 PM
  5. My jeep kicked a$$ today!!!!!
    By Jeepster05 in forum General Chat
