10-23-2022, 05:33 PM #1821
Re: What did you do to your Jeep today?
Finished the rear Napier flat flares on my buddys cherokee, tossed on a glass pack (I advised against it) and replaced a worn idler pulley.
Also put a used JK rear view mirror on my CJ5.
Sent from my iPhone using Jeepz.com mobile appJust
Empty
Every
Pocket
10-23-2022, 06:44 PM #1822
How was the glaspak?
I put the new longer rear shocks on and test drove. Realize i badly need new longer fronts. I also tested some led lights to fit in the new fenders to replace the turn signals/marker ligjts. No-go, to small.
But, progress03 rhd tj
10-23-2022, 07:19 PM #1823
Obnoxious, I apparently went and got old as I used to run one on my TJ, but it’s too loud for me now. Lol
Empty
Every
Pocket
10-24-2022, 12:09 PM #1824
i grew up with glaspaks and straight pipes on cars too. i wonder how it would sound for me, ha ha ha. probably too crazy to me too
03 rhd tj
11-12-2022, 11:53 PM #1825
11-24-2022, 04:33 PM #1826
OMG this better stay connected!!!!!
Rear defogger... I've used multiple adhesives, that have failed to remain connected. I've tried soldering the original little nub... fell off.
This was a last resort! Boogered up the window with enuff solder to hold the wire and hopefully this stays connected!
Connectivity is excellent, so only time will tell. This beats paying the almost $1,500 the stealer wanted to replace the whole window?!? Really... no attempt at mak8ng a repair at all. SMDH
Sent from my SM-S906U using Jeepz.com mobile appWind therapy is the best therapy...
11-24-2022, 10:39 PM #1827
HOW TO Fix Rear Window Defroster! DIY for under $8 - YouTube
Never look down on anyone unless you are helping them up - Jesse JacksonLast edited by JPNinPA; 11-25-2022 at 09:30 AM.
11-26-2022, 10:27 PM #1828
I finally built the little circuits so the leds work as turn signals and running lights, like they should. I got those installed, too. And i put the longer front shocks on and went for a ride.
This jeep is stiff riding now. The kid i got the springs from said they were on hia dad's tj but they are really stiff. Its almost like riding in a 3/4 ton truck. I winder if they were off a jku or something else instead of a tj.
Here is the circuit. diodes and a resistor and the leds in the shot and i had to heat shrink them once soldered in to the jeeps front wiring, too
03 rhd tj
11-26-2022, 10:28 PM #1829
11-27-2022, 12:03 AM #1830
Shrink wrap the wires very well right to the bulb. This is more of a Protection from the rocks and dirt that’ll get kicked up.
Never look down on anyone unless you are helping them up - Jesse Jackson"Never look down on anybody unless you're helping him up" - Jesse Jackson
11-27-2022, 02:45 AM #1831
I pulled the radiator out of my Jeep. Going to the radiator shop on Monday. Nothing exciting.
11-27-2022, 05:44 PM #1832
I wrapped it in the wire protector loom and zip tied them up where the wheels cant twar them off. Them i put that rubber spray liner, really thick and multiple coats, over it all to try to keep it safe.
Time will tell though03 rhd tj
11-27-2022, 06:16 PM #1833
I tried to install my new Xprite lights and the bracket I ordered didn't fit the new lights so now I have to order another
11-30-2022, 07:42 AM #1834
drove it to work. the MPs "love" when i do, ha ha ha, i can tell by how happy they are to have to leave the guard shack and walk to the other side to check my ID.
03 rhd tj
12-04-2022, 11:32 AM #1835
The ol jeep is going to be used a daily today. Going to do a small shake down by using her to run errands in town and maybe head out to port aransas for dinner later. I want to make sure she is good to drive to colorado if my son ends up getting his leave approved from his unit
03 rhd tj
12-04-2022, 05:02 PM #1836
Well... death wobble at 40mph, exactly. And only after the tires are warmed up so i think the tires have gone bad from 1) my son not rotating them, ever and 2) sitting so much since the jeep has been home
03 rhd tj
12-04-2022, 06:20 PM #1837
Id agree tires or rims more likely. DW is fairly consistent starting around 65 mph. But if things are really shaking not just the steering wheel you might check all the bolts and TRE’s, bushings,…
12-04-2022, 08:14 PM #1838
Its just like my old comanche. Starts at 40 and i have to slow down to 25 to stop it. And it doesnt happen from hitting a bump, it will start on a smooth road and you can geel the steering wheel starting to go left to right, just slightly. Than after a while of driving, say 10 miles, as soon as you hit 40mph, boom, you are done. So you either power through to 45 to 50mph and it goes away, or you slow down
I really feel like its a tire but i will find out sometime this week. I will out the 30s or 31s, whatever they are on the jeep. They are brand new, like 5 miles on them. They would be on already but look funny now that the jeep is lifted03 rhd tj
12-16-2022, 10:10 AM #1839
Ok, new steering stabilizer seems to have stopped the problem but i also got some longer lower control arms to install today that should return the caster to stock and hopefully help future death wobbly stay away.
So far, driving the ol jeep to colorado on the 26th sounds like the plan that is mocing forward. Wife and i will drive up and swap with our youngest son and bring the mazda home for home minor maintenance and jarrod can go back out with the jeep club up there on the qeekends, luke he used to do03 rhd tj
12-16-2022, 10:49 AM #1840
Today I'm a new Jeep owner!
By warden37 in forum Wrangler and CJReplies: 9Last Post: 12-27-2010, 09:51 AM -
My Jeep got stolen today...
By 06TJ in forum General ChatReplies: 49Last Post: 12-19-2009, 01:58 PM -
Saw my first Jeep today...
By Mr.Bones in forum General ChatReplies: 2Last Post: 10-22-2008, 01:12 PM -
Got Jeep baptised today
By Deerhunter30 in forum General ChatReplies: 5Last Post: 10-13-2004, 10:54 PM -
My jeep kicked a$$ today!!!!!
By Jeepster05 in forum General ChatReplies: 8Last Post: 07-20-2003, 08:00 PM
