Thread: cj7 tail light problems
04-27-2012, 06:01 PM #1
got a bunch of weird stuff happening with my tail lights, my right passenger tail light went out first, i went to change it out and it looked good but i replaced it anyway and still wouldnt work so i tried to track down the issue going all the way to the driver side light. found a wire that had been split by a rock or whatever put the wire back together and still got nothing. now both tail lights wont work if i turn on a blinker the light stays lit
.....my ground seems to look good, all wires seem to be connected correctly....not really sure where to look next....any thoughts?
04-27-2012, 08:46 PM #2
Whenever you are having weird electrical problems, it's most likely caused by a poor ground.
04-27-2012, 09:16 PM #3
When the directionals are on do the front flash? I would say check your fuses but you probably did that. Could be a bad ground (as stated above), bad or melted switch, or your wiring from drivers tail light to the switch. What I would do is start at the switch and work my way back.
04-28-2012, 06:32 AM #4
Re: cj7 tail light problems
Had the same issue years back.. What I did was take out the bulbs and look inside the socket. You will probably see some blue chaulky looking stuff in there. Clean it!! Use electrical cleaner or get a new socket for it. Then under the rear corners of the jeep where your tail light wiring is, the harness is either spiced or a plug is used to connect the tail lights, do the same with it and clean it. Good chance that will fix it.
04-28-2012, 11:24 PM #5
I think I would check into the blinker directional switch. {turn signal lever on the column} Does that feel loose or have any play in it at all? Had a problem with my yj that the drivers side brake light wasnt working,noticed the turn signal switch was a little loose,and that turned out to be the problem.
YJ Tail light lens
By clydethepirate in forum Items for Sale, Trade, or Give AwayReplies: 0Last Post: 04-10-2012, 10:56 PM -
Tail light issue
By Midnightsecurity in forum Wrangler and CJReplies: 13Last Post: 09-23-2011, 10:13 PM -
LED tail light conversion
By jps4jeep in forum Wrangler and CJReplies: 8Last Post: 01-05-2011, 09:06 AM -
Tail light problem
By HawkStream in forum Cherokee, Commander, Wagoneer and LibertyReplies: 4Last Post: 05-03-2010, 07:20 AM -
LED Tail Light Convertion
By happy024 in forum Wrangler and CJReplies: 13Last Post: 02-01-2006, 10:42 AM
