07-08-2012, 09:59 PM #1
93 wrangler 2.5 cranks but wont start
i hav no power at coil.relays fuses are ok i also changed cam sensor it didnt help. i jumped a hot wire to coil and it will start up but need to fix it right. cps maybe ?
07-09-2012, 06:29 AM #2
Re: 93 wrangler 2.5 cranks but wont start
Ignition control module.
07-10-2012, 03:31 PM Thread Starter #3
07-11-2012, 06:20 AM Thread Starter #4
replaced icm and crank sensor still wont start. this things a pain in my ...
07-11-2012, 07:07 AM #5
Have you replaced the coil? That would be my next guess, or maybe bad ignition switch. Somethings not sending power to the coil or the coil is bad.
07-11-2012, 10:41 AM Thread Starter #6
yea i replaced the coil . im gona try ign switch tnight. the coil not getn any power when i turn over but i can feel the auto shutdown relay kicking in and out.
well that didnt work either i almost have to have a bad wire somewere. anymore ideas please let me know.Last edited by bgreslick; 07-11-2012 at 06:03 PM.
07-12-2012, 07:31 AM #7
Im not real familiar with the wranglers, but I would try and follow the wires from your ignition switch to the coil. If there is anything between the two, thats got to be it. Others with knowledge of sensors and relays may be able to help more. I'll keep thinkin though. I mean, a ignition switch, coil, distributer, control module, alt, starter is about all there is to the starting system and you have replaced half of that. The alt and starter shouldnt have anything to do with the problem your haveing. I bet there is a relay or sensor somewhere in there thats not letting power to the coil.
95 Wrangler wont start....
By markusgov in forum Wrangler and CJReplies: 36Last Post: 01-06-2013, 08:08 PM -
'95 Wrangler sahara 4.0 cranks but won't start
By mbliss984 in forum Wrangler and CJReplies: 6Last Post: 07-21-2011, 09:43 PM -
04 wrangler wont start!
By Dauster500 in forum Jeep Electronics and AudioReplies: 2Last Post: 08-28-2010, 03:21 AM -
96 grand cherokee cranks but won't start
By chester303 in forum Forum relatedReplies: 1Last Post: 02-27-2009, 01:21 AM -
89 yj wrangler wont start
By cali_671 in forum Wrangler and CJReplies: 6Last Post: 03-18-2007, 08:30 PM
