death wobble
todd vanscyoc
my 05 wrangler wobbles at 55mph, checked the trac bar and the upper mount seems to move a little bit. are there bushings in there that can be changed or do i need to replce the whole trac bar?
If i remember correctly, the upper mount to the frame is a balljoint and the lower mount to the axle is a bushing. Either way, the entire trackbar is serviced as a unit unless you find an aftermarket bushing replacement kit for the lower. There are several good writeups and threads on deathwobble in this forum , just go to your search bar and look it up.
